TT’s AIO TH V2 in white and matcha green!
Thermaltake continues to add color to its components. Indeed, the recent AIO TH V2 kits are now available in white and matcha green. However, not all models feature the green version!
TH V2: white and green on the program!
As a reminder, this series of kits comes in many sizes. We have 120 mm, 240 mm, 280 mm, 360 mm and even 420 mm kits. However, while the kits were previously available in black, they now come in white. This color will be available for both ranges: the basic series and the Ultra series with LCD screen. In contrast, the matcha green kit will only be available for the TH280 V2, without a screen.
Without going into too much detail, these AIOs feature a 27mm-thick aluminum radiator. Ventilation is provided by mills from the CT series, in 120 or 140 mm depending on size. Finally, socket compatibility is assured for all recent platforms, with support for LGA-2000/1700/1200/115x. On the AMD s
ide, we find the AM5/AM4 as well as older motherboards with the AM3 and FMx.
Prices, via Thermaltake’s online store, range from $79.99 to $189.99, depending on size and the presence of a display. As for the green model, the bill will reach $109.99!
Here are the Thermaltake product sheets!
