Stella Infinity 120: Gelid fan with double RGB ring!
After his Gale Extreme Gelid comes back with another fan, but a more classic one. Indeed, the brand offers us its Stella Infinity 120, a fan with double RGB ring… As well as an infinite effect lighting on the central hub.
Stella Infinity 120: two light rings for Gelid ‘s mill!
Gelid Stella RGB 120With this new model, the brand offers us a fan of the most classic with a circular frame with silent blocks at the four corners. However, the brand clearly emphasizes the lighting with a total of 24 aRGB diodes distributed over three zones. Moreover, the central hub has an infinite depth effect lighting. If we focus on the characteristics, we will remember its PWM power supply and its speed between 500 RPM and 1600 RPM. The static pressure is announced at 1.3 mmH2O, however, nothing is said about the air flow, it’s a pity. Nevertheless, it is a fan that we can imagine intended for case cooling. Finally, the connectivity is universal thanks to the use of a four-pin fan connector. As for the lighting, we have the right to a three-pin aRGB connector. The bill on this side is not very expensive since the official price is only 12 euros. This is a change from the usual prices charged by some competitors for this type of product!
Here is Gelid ‘s technical sheet!
