Some info on a custom RTX 4060 Ti from Colorful
Via the Twitter account of T4C Fantasy we can get some information related to the future RTX 4060 Ti. However, it concerns a custom model from the catalog of Colorful. The card in question is the iGame Ultra White OC model and we know the amount of memory and its boost frequency.
RTX 4060 Ti: Colorful’s iGame Ultra White OC version reveals some secrets!
Colorful RTX 4060 Ti iGame Ultra White OC
For the time being, the leaker tells us that this card from Colorful will run at 2580 MHz in boost. You have to put this frequency in parallel with the 2535 MHz of the reference card and you get a gain of +45 MHz. This may not seem like much, but it is consistent with the frequency gains generally seen on the market.
As for the memory capacity, unfortunately, no big surprise since this card should be equipped with 8 GB of memory. Again, this remains consistent with the supposed characteristics of the card of reference.
As a reminder, this card should have an AD106 GPU containing 4352 cuda core, 128 TMU and 48 ROP. In addition to the 8 GB of memory, the bus of the latter should be 128 bits, contributing to offer a bandwidth of 288 GB/s. Finally, the heating should be controlled, as well as the power consumption, the TDP of 160W being a good indicator. Finally, rumors mention a PCIe 4.0 x8 interface as well as a free choice of 16-pin or 8-pin PCIe power connector.
