Small AIO Eisbaer Pro ES 2U at Alphacool!
Alphacool announces a new series of all-in-one watercooling kits for servers. For the time being, this takes the form of the Eisbaer Pro ES 2U, ultra-compact kits equipped with 80 mm fans.
Eisbaer Pro ES 2U: AIO for rack servers!
Alphacool Eisbaer Pro ES 2UWith its new watercoling kits, Alphacool offers us ultra small AIOs . Indeed, they are equipped with 240×80 mm and 320×80 mm radiators. Yes, the whole thing is designed to accommodate 80 mm fans. Remember that everything must be mounted in 2U rack cases whose height is very low.
Of course, the radiators are made of copper with a thickness of 60 mm. The whole thing also has two G1/4″ end caps.
The ventilation is therefore provided by three or four 80 mm fans. The fans have a very wide speed range, from 800 RPM to 6000 RPM. At full speed, the air flow is 130.93 m3/h, but the static pressure is unknown.
Otherwise, the brand opts for a DC-LT2 type pump operating at 2600 RPM. It measures 64 (W) x 79 (D) x 54.3 (H) mm. Of course, the base is made of copper and it is connected to the rest of the circuit by two G1/4″ threads. As for the compatibility of the sockets, it will be mounted on the LGA-1000/2000/3647/4189 platforms. On the AMD side, the TR4/sTRX4/SP3/sWRX8/AM4/AM5 are concerned.
Finally, the bill will be significant: between 220 € and 250 € depending on the size.
Here and there are the technical data sheets of Alphacool!
