Lian Li (currently on trial with Phanteks) completes its Uni Fan series with the SL120 V2 Reverse. These are fans whose blades are reversed, in order to enhance the design of the assembly. With these windmills, you can maintain good airflow while keeping the blades hidden!
SL120 V2 Reverse: no more visible blades!
With these fans, the brand is showcasing 120 mm impellers with reversed blades. The aim is simple: to ensure maximum ease of assembly, without having the blades visible at the bottom of the case.
Otherwise, the fan has a classic 120 mm format, but beware of the 28 mm thickness. Depending on the space available, this may cause problems when mounted on a radiator.
Otherwise, the fans are connected via the frame, with connectors integrated directly into them. What’s more, the fans can easily be grouped in clusters, making it easier to manage their speed. Rather than controlling them individually, they can be more easily managed in groups. All this via L-Connect 3 software.
Other than that, the technical data sheet features speeds from 250 rpm to 2000 rpm. At full throttle, airflow rises to 65.4 CFM, while static pressure reaches 2.19 mmH2O.
All that remains now is to find out the selling price.
Here’s the Lian Li product sheet!
