Sharkoon unveils its AIO S RGB series!
The Sharkoon brand launches a whole set of all-in-one watercooling kits under the S RGB series. The latter includes three models, two in 240 mm and one in 360 mm. However, only the 240mm model has a different pump design than the other two.
S RGB: a series of three AIO watercooling kits!
Sharkoon S RGBWith this series, the Sharkoon brand offers us a total of three all-in-one watercooling kits. As said above, the series includes a total of three kits, two in 240mm and one in 360mm. In all cases, we have an aluminum radiator measuring 27.5 mm thick. Nothing extraordinary here.
Regarding the pump, it comes in two models, one with the brand logo, basic. The second version will be more worked with a circumference offering diamond cuts and an infinite depth effect lighting. We also find it much more aesthetic.
Anyway, it offers a copper base and will work from 1600 RPM to 3200 RPM. Finally, its dimensions are 71.5 mm in diameter for a height of 52.3 mm.
In all cases, we have a ventilation provided by mills of 120 mm aRGB powered by PWM. They offer a speed range between 600 rpm and 2000 rpm. At full speed, the air flow will be 131.90 m3/h while the static pressure will reach 2.90 mmH2O.
In terms of assembly, the kits are compatible with all the sockets on the market. Indeed, the LGA-2000/115x/1200/1366/1700 as well as the TRX4/AM4/AM5/AM3 (and earlier) are supported.
For the bill, don’t worry, as you can see in our comparison, the prices are quite affordable!
Here are the technical data sheets of Sharkoon!
