In addition to its Shark Force 120 aRGB, the brand Silverstone offers us a version in 160 mm. In short, here is the Shark Force 160 aRGB, a mill that clearly does not lack breath!
Shark Force 160 aRGB: a 160mm fan that blows a lot!
Of course, with its 160 mm side and 25 mm thickness, this mill plays in a completely different category than the 120 mm version. Moreover, this does not necessarily make it incompatible with all cases. Indeed, it can be mounted where 140 mm fans will go.
Otherwise, this model will benefit from a PWM power supply and semi-passive operation. Thus, it has an operating range between 0 RPM and 1600 RPM. At full speed, the air flow will be important: 160 CFM while the static pressure will remain reasonable with 2.21 mmH2O. This is clearly the kind of fan you want to cool a case!
Just like its counterpart in 120 mm, this version has aRGB diodes in the central hub. The same goes for the specific coating on its blades as well as the possibility of connecting them in series to synchronize the lighting from one mill to the other.
Again the prices are not yet known.
Here is the technical data sheet of Silverstone!
