Shark Force 120 aRGB: Silverstone fan running at 2500 RPM
Silverstone announces a new fan with its Shark Force 120 aRGB. A new fan in 120 mm that promises to be powerful. Indeed, this new model is capable of operating at up to 2500 RPM.
Shark Force 120 aRGB: a Silverstone fan focused on performance!
Silverstone Shark Force 120 aRGBWith this new fan, the Silverstone brand announces a 120 mm mill with RGB lighting. As you can see, the diodes are positioned at the central hub and diffuse the light through the translucent blades. Moreover, the blades have a coating imitating the skin of sharks to improve performance.
Regarding its characteristics, Silverstone announces a semi-passive fan. The range of rotation is therefore between 0 RPM and 2500 RPM. Obviously, at full speed, it will blow hard with an air flow reaching 100 CFM and a pressure up to 4.66 mmH2O. Nevertheless, it is likely that the noise generated will be considerable.
With this, this model comes with removable connectors for easy wiring. Moreover, all kinds of connectors are provided in the accessory part. We find connectors allowing a serial connection for the aRGB part.
Currently, the selling price is not yet known.
This way to the Silverstone datasheet!
