Heading to CES 2024, Samsung is announcing a range of new displays. On the program are the Odyssey OLEDs, a range comprising three monitors. They include the G95SD, G80SD and G60SD!
Odyssey OLED: three high-end displays for Samsung!
With this new batch of screens, the brand offers us three new references. Two of these are in 16:9 format, while the third, much larger, is in 32:9.
Naturally, this immediately gives an indication of the resolutions involved, with the G95SD displaying a DQHD resolution of 5120×1440. The G80SD, meanwhile, will be in UHD, all on a 32″ flat panel. Finally, we find the small G60SD, a 27″ monitor in QHD (2560×1440).
What these models have in common, however, is their high reactivity and frequency. We’re talking 240 Hz for the DQHD and UHD models. The little G60SD, on the other hand, displays at 360 Hz! In all cases, latency is 0.03 ms gray-to-gray.
For the moment, full technical specifications are not available. However, we do know that they benefit from VESA DisplayHDR True Black 400 certification. At the same time, FreeSync Premium Pro is also on the program. As for connectivity, we know that HDMI 2.1 and DisplayPort 1.4 are on the program, as is a USB hub. Finally, a VESA mount is provided if required, while an adjustable stand is included by default.
Of course, we’re expecting high bills!
