A new graphics card joins the AMD catalog: the RX 7800 XT Hellhound Spectral White. It’s a Hellhound version, but completely white, from the shell to the PCB!
RX 7800 XT Hellhound Spectral White: new CG for PowerColor!
With this card, we’re back to an all-white model. As you can see, the fairing, heatsink and PCB are completely white. For their part, the three fans are translucent, allowing the lighting to be better diffused. Otherwise, the blackate is also all white, with a gray Hellhound logo.
In terms of dimensions, the card remains quite long at 322 mm. However, it will only occupy two and a half slots in height. As you can see, the radiator features two blocks of aluminum fins crossed by copper heat pipes.
In terms of frequencies, the card operates at 2520 MHz boost, with an in-game frequency of 2213 MHz. Compared to the reference card, this is a factory overclocked version, since the original card’s boost is 2430 MHz. As for memory, there’s no change, with VRAM running at 19.5 Gbps.
Lastly, as far as connectivity is concerned, we find a dual 8-pin PCIe connector for the power supply. As for video outputs, one HDMI 2.1 and three DisplayPort 2.1 are present.
For the moment, no price has been announced, but we imagine the bill will be similar to the current black model!
Here’s the PowerColor product sheet!
