Galax (KFA2 in Europe) doesn’t only make RAM or graphic cards. Via Vonguru, you can discover their mouse and their seat. Anyway, today we learn about a case from the brand, the Rev-03. It is a micro-ATX reference with an interior layout that is off the beaten track. An original case? We like it!
Rev-03 : a micro-ATX case signed Galax !
If you like cases that are out of the ordinary, you will probably be won over by this model. Inside, there is enough room for a mini-ITX or micro-ATX motherboard. However, the graphics card can be placed vertically in front of it, leaving little room (88 mm) for the CPU cooling unit. In these cases, we can only recommend you to install an AIO with the heatsink at the bottom. Finally, as far as the power supply is concerned, we will be forced to use an SFX format block.
The basic ventilation is not very well provided since only one fan in 80 mm is supplied. To complete it, you will have to add 120 mm fans: two on the top, two on the bottom, or two on the side, via a removable plate. Only constraint for this plate, not to install GPU vertically.
Finally, as far as storage is concerned, Galax puts forward three 3.5″ slots and three others in 2.5″. Enough to do at this level.
In short, all these possibilities are offered in a case measuring 185 (W) x 391 (D) x 303 (H) mm. Note that the different panels of this Rev-03 are perforated. The goal is to let the machine breathe as much as possible.
