PowerColor launches an RX 9060 XT Hellhound Spectral White
PowerColor has added a new graphics card to its RX 9060 XT range, the latest consumer board to be released by AMD. The brand is now offering an all-white version of its Hellhound model, the RX 9060 XT Hellhound Spectral White! Both the PCB and fairing are white.
RX 9060 XT Hellhound Specrtal White: all white!
RX 9060 XT Hellhound Spectral WhiteWith this new graphics card, PowerColor offers us a card whose length could be a hindrance, depending on your case. In fact, the card measures 31 cm in length, all for two strict slots. In an ITX case, for example, the length could pose a few difficulties. Otherwise, we find a smooth white casing, which reveals three fans. These fans blow over two blocks of aluminum fins crossed by four 6 mm copper heat pipes. Finally, a nickel-plated copper base is used for the memory and GPU. No thermal paste as such, but a Honeywell PTM7950 pad on the GPU. As for the PCB, it too is totally white, a little like that found on the Galax HOF, but nowhere near as massive. As the GPU is very small, the circuit has 5+1 power supply phases. On the frequency side, dual bios are present. You can choose between the Silent bios, which run the GPU at 3230 MHz, and the OC bios, which run the GPU at 3310 MHz. By way of comparison, the reference card runs at 3130 MHz, so with the Silent bios alone, we’re faster than a reference card! Finally, in terms of connectivity, we have three video outputs, with one HDMI 2.1b and two DisplayPort 2.1a. The power supply is an 8-pin PCIe. The price is now known: $480.
Click here for the PowerColor product sheet!
