MD2: a G.Skill case with a front panel reminiscent of its Trident Z5!
New case at G.Skill which already has some references in its catalog. The brand announces a new medium tower model with the MD2. A new reference which will be made in collaboration with Geometric Future of which we had presented you some models here and here.
MD2: a front panel with a well-known G.Skill shape!
G.Skill MD2In the program, we find a case in the medium tower format whose dimensions are still unknown. However, inside, there will be room for ATX motherboards. On the GPU side, there will be no real limitation with almost 40 cm of free space. Regarding the CPU fans, we are at 170 mm.
The storage part remains quite classical with a HDD cage of two 2,5″/3,5″ baskets. Two other 2.5″ decks complete this set.
For the cooling, visibly, it will be the classic compatibility since we could install up to seven fans. For watercooling, the compatibility goes up to 360 mm with a slot in front and in the top.
However, what we will remember about this model is its front panel with a very particular look. Indeed, the latter reminds us of the shape of the heatsinks of the Trident Z5 of the brand.
Regarding the price, colleagues at EXPreview evokes 459 yuan in black and 499 yuan in white, or between 65 € and 70 € after conversion.
