MAG Meta S : MSI’s PC upgrades to Ryzen 5 5600X !
MSI updates one of its pre-assembled PC, the MAG Meta S, a compact machine. This one is now based on an AMD Ryzen 5 5600X processor and leaves the small Ryzen 5 3600 aside. Nevertheless, keep in mind that we are on a machine dedicated to 1080p!
MAG Meta S : MSI updates its small PC !
MSI MAG Meta S This is a machine preassembled by MSI. Nevertheless, the brand seeks to offer you a compact PC with dimensions of 185 (W) x 480 (D) x 422 (H) mm and a weight of 8.74 kg.
Internally, our machine is now equipped with an AMD Ryzen 5 5600X processor, a model with six cores operating at 3.6 GHz. This is mounted on a motherboard with an A520 chipset and up to 64 GB of DDR4 RAM. On the GPU side, we have the right to a GTX 1660 Super. Clearly, this is a PC that will be used for gaming on small resolutions.
Otherwise, the CPU is cooled by an air cooling solution. As for the power supply, we find a 500W block with a small 80+ Bronze certification. Finally, the storage will be via a 510GB M.2 NVMe SSD.
For now, we do not know the price, however, no doubt that this model will be more affordable than others.
Here is the technical data sheet from MSI!
