Jonsbo announces its TH-series AIO!
New watercooling kits from Jonsbo, who are offering us a new series with their TH-Series. The programme includes black or white AIOs, all with a digital display that measures CPU temperature only. But there’s another special feature, as we shall see.
Jonsbo TH-Series, a series of four kits!
Jonsbo is offering a range of watercooling kits with 360 mm and 240 mm radiators. In terms of colour, there’s a choice of black or white kits. In all of them, there is aRGB lighting on the pump and on the sides of the fans. What’s more, the ventilation benefits from an infinite depth effect.
As for the pump, you won’t have missed the digital display. However, it’s not a screen like you’ll find on NZXT’s new Kraken Elite or Corsair’s iCUE Link LCD kits. No, this is a very simple display that will only report the temperature of your processor.
The other special feature of these kits is that they opt for a fan that shares a single frame. So you end up with a double or triple fan to be fitted in a single operation. While this system makes assembly easier, we still have some reservations about its reliability. If one of the mills breaks down, the whole unit will have to be replaced.
Be that as it may, in terms of characteristics, we’ll retain an operating speed of between 700 and 2400 rpm. At full throttle, we know that the airflow will reach 62.40 CFM, while the static pressure is unfortunately unknown.
Finally, regarding the pump, the brand mentions compatibility with Intel LGA-1200/115x/1700/1851 and AMD AM4/5 sockets.
Pricing is not yet known, but we expect it to be aggressive.
Here are the Jonsbo product sheets!
