Jonsbo announces its N10 and NV10 cases with a volume of 4.54l!
From Jonsbo, we have the announcement of new cases featuring ultra-compact volumes. In fact, the N10 and NV10 are very similar models that boast an ultra-small volume of 4.54l. If you don’t have a lot of space on your desk, this could be a solution to consider.
N10 & NV10: just 4.54l of volume!
Jonsbo N10 & NV10jonsbo
On the programme, we find very classy cases with their 3.3mm-thick aluminium-based construction. Internally, however, the chassis is made of 1mm-thick steel, to ensure a degree of rigidity. In any case, you won’t need much more than that, since the dimensions remain very compact in both cases, with 205 mm on each side and 108 mm high. As for weight, there’s no risk of breaking your back with just 1.5 kg on the scales.
Inside, you’ll be able to install a mini-ITX format motherboard and a CPU cooling unit, which shouldn’t be more than 38 mm high. As for the power supply, there’s no choice: you’ll need a 1U Flex unit less than 15 cm long. Clearly, this isn’t the kind of PSU you’ll find on every street corner!
Jonsbo NV10
The NV10 with its graphics card support
Now, between the N10 and the NV10, we find a major difference: graphics card support. The NV10 is distinguished by its support for a half-height graphics card, whereas the other case has an SSD cage that can accommodate up to four 2.5″ units.
Otherwise, the two cases are identical and will allow vertical or flat orientation. The control panel consists of a simple power button and a single USB-C socket. What’s more, the control panel is enhanced by a strip of real walnut, giving these cases a very classy look!
