InWin POC : a box in a pizza box…
If the oldest of us know InWin for years, the brand has become known to a younger audience in recent years with rather extravagant cases. InWin is back with its POC PC Case. A kit case delivered flat in what looks like a pizza box. The idea? With this kit, you have pre-cut foldable steel panels that, once fully built, form a rather original mini-ITX chassis. The seven-piece kit, when fully assembled, measures 256 mm x 278 mm x 423 mm and weighs a revised 4.2 kg. Divided into two areas, the interior of the case allows the use of a standard ATX power supply up to 160 mm deep and to mount in another area a dedicated GPU with a size up to 3.5 slots and up to 346 mm long. However, you will have to stick to the mini-ITX motherboard.
InWin POC
InWin POC: original and offbeat
This chassis is intended to be the first of a series that was mentioned in early 2023 during CES as part of the iBuildiShare product line. As you can see, the idea is to offer products with a focus on modular design and DIY.
The InWin POC will be available in bright blue and black (IW-CS-POCBLU) or bright green and yellow (IW-CS-POCGRE). A price around 100€ whatever the color is considered. In addition, the modular design offers excellent modularity options. For example, a top panel, side cover or motherboard slot can be purchased separately for only $18, while a replacement PCIe 4.0 mounting cable costs $59.
InWin POC VGA part InWin POC
