Intel, first to release a driver for Hogwarts Legacy!
Finally, Intel will be the first graphics card manufacturer to release a driver for Hogwarts Legacy. Indeed, the company publishes its driver in version 101.4123 BETA. Of course, it brings support for the last game in the Harry Potter universe as well as for Returnal!
Arc GPU Graphics Drivers 101.4123 BETA: support for Hogwarts Legacy
Hogwarts LegacyStrangely, this new version of the Intel driver does not bring any fixes. We will “only” find support for the long-awaited Hogwarts Legacy. Returnal, is also concerned by this new driver from the blue.
As said, no patches brought, nevertheless, the company continues to identify problems. These include their in-house application Arc Control:
  • An administrator UAC level is required to install and launch Arc Control
  • The live monitoring page may not enforce the removal of some tiles.
  • The Resizable Bar status may show incorrect values on systems with multiple Intel GPUs .
  • Using Arc Control Studio to capture some games may generate multiple video files incorrectly.
  • Using Arc Control Studio with an AVC CODEC may incorrectly use the HEVC CODEC.
  • Also note the possibility that performance changes via sliders may not apply for a return to default values. This can be circumvented by using the ” Reset to Default ” button.
And with this, we will find many concerns related to games under DirectX12, DirectX 11 with dedicated GPUs and iGPUs. And so on. But if you want to take advantage of the support for the latest title taking place in the Harry Potter universe, it’s here!
