HOF GH 1300W : a Galax PSU with two 12VHPWR connectors
Galax launches a new power supply with its HOF GH 1300W. As you may have guessed, it is a high power block offering a good performance. Nevertheless, its particularity is in its connectors which support two 12VHPWR connectors.
HOF GH 1300W: two 12VHPWR connectors for the Galax power supply !
Galax HOF GH 1300The brand offers us a really compact power supply. Indeed, despite its 1300W power, this model is only 14 cm deep!
Otherwise, we will retain its particular connectivity. Unlike other power supplies on the market, this one has two 12VHPWR connectors. So we are ready to power a hypothetical Titan RTX, we told you about it here. But in broad terms, the card would have two of these connectors. Otherwise, via this block, we can count on ten PCIe 6+2 pins, twelve SATA and a few Molex.
Finally, the construction is based on 100% Japanese capacitors and an efficiency of 94% at 50% load thanks to its 80+ Platinum certification. Finally, on the ventilation side, we find a 120 mm mill with semi-passive operation. Ah, by the way, the block is ATX 3.0 compliant, allowing it to output up to 2600W at peak consumption.
For the blow, the bill soars, Tom’s Hardware 3199 RMB excluding promotions, or about $465.
