New power supply signed Silverstone with the Hela 1300R Platinum. It is a high power block that completes the Hela series currently in place at the brand. Moreover, it will be able to count on a compact format of only 14 cm deep!
Hela 1300R Platinum: a high-powered power supply with 14 cm depth!
With this new model, Silverstone continues to deploy high power supplies in a small format. Indeed, if we are dealing with an ATX block, the depth of it remains contained: only 14 cm. This format will allow the installation of a 120 mm fan type FDB with semi-passive operation. It will only start up after 260W of consumption.
In terms of connectivity, we have everything necessary to power large configurations. Indeed, in addition to the usual 24-pin ATX and dual EPS12V 4+4 pins, we also have 8 PCIe 6+2 pins connectors. Likewise, the 12VHPWR is also present. The peripheral part benefits from 8 SATA, 6 molex and two floppy.
From an electrical point of view, the block displays a large certification with 80+ Platinum. Internally, we find capacitors of Japanese origin, like any self-respecting power supply. Likewise, it also offers a single 12V rail of 108.3A and the following electrical protections: OCP, OPP, OVP, OTP, UVP and no-load protection.
Again, no price. Be careful though, as this unit will clearly add weight to your PC with its 2.93 kg on the scale.
This way to the Silverstone datasheet !
