Bitfénix announces new all-in-one watercooling kits with its Glanz series. What’s special about the Glanz series? A screen? No, a focus on RGB? Yes, but the brand goes further than simply adding LEDs here and there, since the pipes are also illuminated. More and more… We wonder how long we’ll have to wait before we see illuminated radiators!
Glanz: AIOs with illuminated pipes!
Available in 240 and 360 mm!
With this series, the brand offers us kits that will be “just a little bit” flashy when the PC is powered up. Not content with the usual RGB on the fans and pump, the brand goes so far as to include RGB in the hoses. So how do they do it? That’s the question, although we presume they’re using a white or translucent sheath with fiber optics running through it to diffuse the lighting… A bit like Lian Li’s Streamer extension cables!
Otherwise, on the radiator side, we find a classic aluminum heat exchanger, 27 mm thick. Otherwise, the finish looks decent, with square corners and hidden rivets/screws. The pump features a rather compact hood measuring 69.5 x 89 x 60 mm. As for speed, it will run at up to 2500 rpm.
Ventilation is provided by two or three 120 mm fans. These will operate at up to 1800 rpm. At full speed, the airflow generated will reach 75.84 CFM, while static pressure will rise to 2.27 mmH2O.
A bill for which the amount is still unknown:
For the moment, we don’t yet know the amount of the bill. However, as Bitfénix is a rather entry/mid-range brand, we don’t expect the price to explode, as can be the case with someAIO brands. What’s more, the absence of a screen suggests that the price should be kept under control.
Here’s the Bitfénix product sheet!
![[Tweak League] Tutorial: Overclock your RTX 4060 and get 10% FPS](https://en.overclocking.com/wp-content/medias/sites/4/2024/07/overclocking-gpu-rtx-4060-occ-scaled-218x150.jpg)
