FC120 aRGB: new fans from DeepCool!
DeepCool announces new fans with its new FC120 aRGB. New fans with aRGB lighting, but also offering a new design. The goal is to stick to the new charter that the brand gives itself.
FC120 aRGB: rather sober RGB fans!
DeepCool FC120 aRGBWith its new fans, the brand offers models of square shape in 120 x 120 x 25 mm. Of course, there are rubber silentblocks at the corners of the frame. Finally, a small detail that is important, DeepCool announces that the blades of its fans are made of PBT. A plastic more resistant than ABS.
Nevertheless, what interests us the most are their characteristics. Powered by a PWM signal, these FC120 offer a speed range between 500 RPM and 1800 RPM. At full throttle, the airflow will be rather correct with 61.91 CFM announced. As for the static pressure, it reaches 1.83 mmH2O. A mill that seems rather versatile on paper.
Of course, we can’t miss the RGB lighting of this reference which is diffused on the blades. However, we find a small particularity: a serial connection, a bit like the Saturn ASN120/140 of In Win. Indeed, a single cable is enough to connect a whole cluster of fans, which is quite practical!
In terms of price, it will cost a little over 40 euros on Alternate.fr in a pack of three. Each unit will cost more than 16 euros, note that they are available in black or white.
Here is the DeepCool technical sheet!
