Silverstone announces a new power supply, but also a small innovation. Indeed, the small Extreme 850R Platinum is not only a powerful SFX block, but also the first SFX12V 4.0 compliant block!
Extreme 850R : a first SFX12V 4 .0 block !
With this new model, Silverstone offers us a power supply in SFX format. This one has a comfortable power of 850W and a certification with Cybernetics Platinum!
However, it is also distinguished by its compliance with the SFX12V 4.0 standard. This means that it uses the specifications of the ATX 3.0 standard while being equipped with a 12VHPWR connector.
Otherwise, this block has a single 12V rail that can deliver 70.8A. Of course, the construction involves capacitors of Japanese origin. The design uses an LLC type circuit and also benefits from an active PFC . And for the protection part, you can find OCP,OPP,OVP, SCP,UVP and OTP.
In terms of connectivity, you should know that it is fully modular. Secondly, this model features a single 24-pin ATX and a duo ofEPS12V 4+4 pins for the CPU. To power the graphics part, we have two PCIe 6+2 pins as well as a 12VHPWR capable of supplying up to 450W. Finally, eight SATA, three molex and one floppy are included.
We end by mentioning the five-year warranty and the selling price of $215.99!
This way to the Silverstone datasheet!
