Endorfy announces its Navis F240 and F360 aRGB kits!
The brand Endorfy, formerly SilentiumPC following a name change, announces new watercooling kits. The brand completes its Navis series started some time ago. The program includes two all-in-one watercooling kits with 240 mm and 360 mm heat sinks, all sprinkled with aRGB lighting!
Navis F: two new aRGB kits in 240 mm and 360 mm!
SilentiumPC Navis F360 aRGBThe Polish brand is offering all-in-one watercooling kits. These kits are equipped with 240 mm or 360 mm heat sinks capable of accommodating two or three fans per side. However, the construction is made of aluminum and they measure 28 mm in height.
As for the pump, it has a copper base while it will operate from 1600 rpm to 2600 rpm.
As for the ventilation, we know that there are two or three fans type Fluctus 120 PWM aRGB. These will run from 250 rpm to 1800 rpm. Unfortunately, we will not know more about the static pressure or airflow. Also, expect extreme silence at low rpm… But also to a lower performance.
Finally, it only remains to talk about the compatibility of the sockets which is assured for the AM4 and AM5 of AMD. At Intel, the kit will go on the platforms in LGA-2000/1700/1200/115X.
On the price side, the bill will not be that exaggerated with prices of € 99.00 for the 240 mm against € 129.00 for the 360 mm officially. The good news is the availability in our stores.
Here and there the technical data sheets of Endorfy !
