Eleos 12 RBW: six heat pipes in direct touch at Raijintek!
A little tour at Raijintek which announces a new heatsink with its Eleos 12 RBW. In the program, we find aircooling in 120 mm with a radiator well furnished with heatpipes. However, like the Themis II however, as with the RBW, all this little world is in direct contact with the CPU.
Eleos 12 RBW: 6 heatpipes in direct-touch on the new Raijintek ventirad!
Raijintek Eleos 12 RBWWith this new heatsink, the brand announces a model with dimensions of 127 (W) x 75 (D) x 164 (H) mm. The weight is rather contained with 610 g on the scale, not enough to fold a socket.
The radiator has a full black finish, we find it on the fins and heatpipes. On the top, we note the presence of a cover sublimated by an aRGB lighting. Still related to the radiator, if the number of fins is not specified, we know that six 6 mm copper heat pipes in direct contact with the CPU are part of the game.
Concerning the ventilation, we have the right to a single fan of 120 mm with a lighting on its central part. Powered by PWM, this mill has a rotation range between 800 RPM and 1800 RPM. At full speed, the airflow rises to 75 CFM when the static pressure reaches 2.3 mmH2O.
For the moment, we do not know the selling price of this model. However, it will be compatible with LGA-1700, LGA-1000, LGA-2000 as well as AM4 and older.
Here is the Raijintek datasheet !
