At the beginning of the year in the past, we talked to you about the E1, a new case from EVGA. However, if we knew that it was made of carbon fiber, we didn’t know its price. The news has just come out and you’ll have to have a well-stocked wallet. The basic version will cost $1599.99!
E1: prices between $1599.99 and $4999.99!
The main thing we will remember is the crazy price charged by EVGA since the case is displayed between ~$1500 and ~$5000. But then, what do we have for this price?
The most expensive version comes already well equipped since it is in fact a bare bones. In other words, we have the case, the graphics card, the motherboard, the power supply, a vertical mounting kit, the PowerLink and the premium carrying case. The components are qualitative since the GPU is none other than an RTX 3090 Ti KingPin when we find a Z690 Dark KingPin as a motherboard. Finally, the power supply will be powerful: 1600W. The intermediate model is priced at ~$3700 and offers :
- The case
- The vertical mounting system for the graphics card
- An RTX 3090 Ti KingPin
- And a 1600W power supply!
Finally, there is the base case at ~$1600 with the vertical mounting kit.
E1 : what about the specs ?
Just the case itself is impressive with its carbon fiber construction that makes it extremely light: 9.88 lbs (~4.5 kg)… Especially when you consider its dimensions of 320 (W) x 590 (D) x 610 (H) mm. Moreover, it is original with its motherboard support suspended by a steel suspension system. Moreover, it will be able to accommodate large motherboards: E-ATX at most. Otherwise, there will be no real limitation as to the components except for the support of watercooling radiators: 360 mm maximum. Finally, it is distinguished by the presence of a control panel with three analog gauges. These will inform the temperature of the graphics card, the processor and the system as a whole!
This way to the EVGA datasheet!
