Corsair DDR5 ready for overclocking via EXPO
As we mentioned in this brief, AMD will launch its EXPO technology(Extended Profiles for Overclocking). It will allow you to overclock your DDR5 memory kit in one click. Corsair has just announced that it already has compatible kits. The brand announces today the launch of DOMINATOR PLATINUM RGB DDR5 for AMD, VENGEANCE RGB DDR5 for AMD and VENGEANCE DDR5 for AMD. These kits feature the new AMD EXPO technology and are ready to accompany the next generation of Ryzen 7000 series PCs. Les kits Corsair DDR5 AMD EXPO They will be available in frequencies up to 6000 MT/s initially and higher later. Thanks to AMD EXPO technology, these modules will be configured to their nominal speed and performance in just a few clicks.
DOMINATOR PLATINUM RGB DDR5 kits:
This kit features the DHX cooling system, 12 ultra-bright CORSAIR CAPELLIX RGB LEDs and forged aluminum heatsink. It will be available in a gray color exclusive to the CORSAIR DDR5 series for AMD. Continuing the tradition of delivering uncompromising performance, the DOMINATOR PLATINUM RGB DDR5 for AMD features only sorted high-frequency memory chips (product sheet).
VENGEANCE RGB DDR5 kits:
This series also adopts a new look with its gray aluminum heatsink featuring a panoramic RGB light bar, illuminated by ten individually configurable RGB LEDs. These kits combine tight latency and high performance (product sheet).
VENGEANCE kits :
This series of sober memory kits in a minimalist style will keep your memory cool with its gray aluminum heat sink, and the format will effortlessly fit any system. All of these memory kits for AMD are available now through CORSAIR’s online store and authorized distributors and resellers. They are sold with a limited lifetime warranty backed by the customer support network.
