Cooler Master MasterLiquid Atmos : an eco-friendly AIO
At CES, Cooler Master also announced a new line of all-in-one watercooling kits with the MasterLiquid Atmos. The program includes two kits in 240 mm and 360 mm. Nevertheless, the brand emphasizes the eco-responsible side with the use of sustainable materials or from recycling.
MasterLiquid Atmos: an eco-friendly AIO!
Cooler Master MasterLiquid AtmosIn the program, the brand announces two all-in-one kits with a 240 mm version and a second one in 360 mm. However, all the characteristics are not yet known. We know that the kit comes with new SickleFlow fans that can operate up to 2400 rpm. Otherwise, as for the airflow or static pressure, we do not know yet.
In addition, the brand highlights the eco-responsible side of kit via the use of recycled plastic for the cover of its pump. Otherwise, the radiator is made of aluminum, a material that is also very well recycled. On the other hand, the RGB is massively present, both on the fans and the pump.
Otherwise, we learn that this series will arrive with the brand’s controller, allowing software support via Master+.
Finally, the use of recycled plastic for this kit is a good idea. Moreover, more and more brands are going green. We think in particular of NZXT or Alphacool which use more basic packaging on some products. It remains to be seen when the brand will launch its product on the market.
