Cooler Master launches its Hyper 622 Halo!
Cooler Master announces new fans for your CPU with its Hyper 622 Halo. These models are available in black and white and follow the recent Hyper 212 Halo. Anyway, we are talking about dual tower heatsinks!
Hyper 622 Halo : the double tower cooler from Cooler Master with RGB sauce !
Cooler Master Hyper 622 Halo noirOn the program, Cooler Master offers us a double tower heatsink. The set is rather imposing with 125 (W) x 137 (D) x 157 (H) mm. Fortunately, the height remains rather contained with less than 160 mm.
Otherwise, we find two stacks of aluminum fins crossed by a total of six copper heat pipes. These last ones join at the level of the base, it also in copper. Nevertheless, it is not eccentric, beware of memory compatibility since there is only 40 mm under the first fan.
Speaking of fans, two MF120 Halo² powered by PWM. They run from 650 rpm to 2050 rpm. At full speed, the airflow will be 51.88 CFM while the static pressure will reach 2.89 mmH2O.
Cooler Master Hyper 622 Halo blanc
Socket compatibility remains very classic with support for mainstream platforms.
For the moment, prices are not known.
Here and there are the Cooler Master datasheets !
