BO400: a truly stylish Jonsbo case!
Jonsbo has announced its BO400, a new model that promises to be extremely attractive. With this new reference, the brand unveils an imposing aquarium-type model with compartments. But as you’ll see, this model has a little something extra that gives it an almost military look!
BO400: a convincing new case from Jonsbo?
Jonsbo BO400
With this new model, the Chinese brand is offering us a compartment-type case providing an unobstructed view of your configuration. As you can see, it has three tempered glass panels: on the top, on the front and on the side. However, the brand is not trying to hide the pillars as you can see. On the contrary, the pillars are very present, but they are also worked, with rounded corners. This is very reminiscent of Cooler Master’s MasterFrame concept!
More concretely, the dimensions are rather substantial at 311 (W) x 474 (D) x 489 (H) mm. This means the case can accommodate motherboards up to ATX format. The same applies to graphics cards, with a space of 435 mm compared with 173 mm for CPU fans. Finally, the power supply unit has a clearance of 200 mm.
Ventilation capacity is also considerable, with no less than ten 120 mm slots for fans. As for watercooling, compatibility with radiators goes up to 360 mm at the top, bottom or side of the motherboard.
Jonsbo BO400
On the storage side, this model offers up to two 2.5″ slots, and up to four 3.5″ slots. Given current production levels, more 3.5″ slots are quite rare.
Finally, the control panel is fairly standard, with dual USB-A 3.2 Gen1 connectors coupled with a USB 3.2 Gen 2 type C.
All that remains is to find out the retail price.
Here’s the Jonsbo product sheet!
