A 48.9″ DQHD 240 Hz Predator X49 X OLED from Acer
The Acer brand is turning up the heat on a new display that promises to be very high-end. The company is teasing its Predator X49 X, a reference equipped with an imposing 49″ OLED panel!
Predator X49 X: an OLED screen with a 49″ panel!
Acer Predator X49 XWith this model, you’re clearly going to need a lot of room on your desk, especially when you consider that a 34″ monitor is around 80 cm wide… Here, we’re talking about a width of 1.2 m, which is a criterion you need to take into account when making your purchase.
Otherwise, this reference is equipped with an imposing OLED panel, curved at 1800R. It then displays a DQHD resolution of 5120×1400, all at high frequency: 240 Hz. Latency is also low, at 0.03 ms.
On the display side, we find a typical brightness of 250 nits, which can rise to 1000 nits. In any case, this is a DisplayHDR True Black 400-certified monitor.
Otherwise, for connectivity, we find HDMI 2.1 coupled with DisplayPort 1.4a.USB-C is also present, providing 90W of power for recharging some of your devices. Finally, there are two 5W speakers.
