Intel has released a new version of its Arc Graphics Driver, version 101.4576. This new version is simply a patch release. There are no new optimizations or support, just two small fixes.
101.4576: a small patch release!
In the final analysis, Intel’s new release brings just two small fixes. The blue ones correct
- Problems with corrupted textures on Remnant II in gameplay (DirectX 12).
- Texture flicker on World War Z (DirectX 11) in gameplay is also corrected.
So if you play the two titles mentioned above, this update is for you. If not, you can totally miss out.
Even so, there’s still a whole list of known unresolved issues. For example, the Intel change note mentions:
- Shadow of the Tomb Raider may crash after loading the game
- Blender 3.6 may crash during rendering when hardware Ray Tracing is active
- Adobe After Effects may crash during rendering operations
- With some games, Arc Control Studio may incorrectly generate multiple video files.
- Etc.
To download, go to the link below:
