Zephyr unveils its RTX 3060 Ti with pink PCB!
The Chinese brand Zephyr offers us a new graphics card with an RTX 3060 Ti. This small, compact card features a pink printed circuit board. This color is also found on the fan.
RTX 3060 Ti: a pink PCB from Zephyr!
Zephyr RTX 3060 TiWith this model, Zephyr offers us a cute card with a white fairing and pink fan. The PCB is also a pretty shade of pink, while the backplate features flower-shaped cut-outs.
However, this is an ultra-compact model with a length of just 172 mm. Clearly, this is a card that will fit into any PC case on the market.
On the other hand, the card does not benefit from any factory overclocking, as it operates at base frequencies. We therefore find a model running at 1665 MHz boost, while the memory is still running at 14 Gbps.
Finally, in terms of connectivity, the card features three DisplayPorts and one HDMI. Despite its compact format, an 8-pin PCIe connector for power supply will be required.
However, this is a purely Asian card that won’t see the light of day over here. To get your hands on one, you’ll have to go through an via import.
