At ADATA/XPG, new components were announced. These include new power supplies with the Core Reactor II VE series, and fans from the Vento range.
Core Reactor II VE: power supplies from 650W to 850W!
Power supplies come in 650W, 750W and 850W versions. These models feature modular cable management and 80 Gold certification. What’s more, they are ATX 3.1-compliant, and all feature a 12V-2×6 cable for NVIDIA RTX 40 power supplies.
Internally, we’re entitled to the necessary electrical protections with OVP/OPP/SCP/OCP/UVP/NLO/SIP. Finally, the company boasts very low ripple noise on its various rails.
Finally, we’d like to mention the compactness of these blocks, with a carcass only 14 cm deep.
The Vento fan family expands!
The Vento 120 aRGB PWM and Vento R 120 aRGB PWM fans are two new models. While the former is a classic, the latter features inverted blades. The aim is to offer maximum performance when the mills are mounted in suction mode at the bottom of a case, for example.
In both cases, the mills are 120 mm in size and available in black or white. As for features, we have :
- Vento R 120 aRGB PWM :
- Speed: up to 1600 rpm
- air flow: 65 CFM
- Static pressure: 1.65 mmH2O
- Vento 12 aRGB PWM :
- Speed: up to 1850 rpm
- air flow: 50 CFM
- Static pressure: 1.5 mmH2O
All that remains is to find out the price. Availability will be limited, as XPG is not very well distributed in France.
