XE04-SP6P: a server cooling unit from Silverstone!
Silverstone doesn’t just make hardware for the consumer sector, no, the brand also offers server hardware. The proof is in the new XE04-SP6P heatsink for SP5 and SP6 platforms!
XE04-SP6P: a heatsink for SP6 and SP5 sockets!
Silverstone XE04-SP6PThe program features a compact heatsink measuring just 130 (W) x 119 (D) x 126 (H) mm. This heatsink can be installed in 4U rack servers and tower-format cases.
What sets it apart from consumer heatsinks, however, is its ability to dissipate watts. In fact, it is designed to handle 350W TDPs. While this may seem enormous in view of the dimensions, it should be pointed out that the fan supplied does not really have the noise constraints of the consumer sector. Here, the 92 mm mill operates at up to 5000 rpm. At full speed, it generates an airflow of 77.7 CFM and a static pressure of 10.67 mmH2O.
This cooler also benefits from a nickel-plated copper base and pre-applied thermal paste. Finally, there are a total of five 6 mm copper heat pipes.
No price yet.
Here’s the Silverstone product sheet!
