Vida Slim: slim watercooling kits at Silverstone!
At Silverstone, we learn that the brand is about to launch its Vida Slim watercooling kits series. A series of models with the particularity of offering fans and a slim radiator.
Vida Slim: AIOs with slim fans and radiators!
Silverstone Vida Slim SeriesFor the moment, we do not know much about this series of watercooling kits, the brand has not yet put online the technical specifications. However, via our colleagues at TechpowerUp we know that several models are on the program. We can logically expect to see kits in 120 mm and 240 mm. For the 360 mm, we will not put our hand to cut. As we see it, this series is suitable for ITX configurations. In short, when we say “slim” what do we mean by that? Quite simply, a 22 mm thick radiator, as opposed to the usual 27 mm or more. Moreover, in order to further reduce the size of the radiator + fan group, the mills will also be in low profile format with 15 mm thickness. Finally, the mills should operate up to 1850 RPM and generate an air flow of 68.33 CFM and a static pressure of 2.59 mmH2O. The information related to the pump is not known yet… The same goes for the price or the launch date. Anyway, the idea is original and allows to propose cooling for the most compact cases. As a reminder, a long time ago, we tested the Toundra TD02-Slim to give you an idea of what it looks like.
