Vengeance a7400: Corsair PCs pre-assembled with Ryzen 9000
In addition to retailing computer components, Corsair also offers pre-assembled systems. These include the One i500, of course, but also larger PCs such as the recently launched Vengeance a7400 range. The latter features the latest AMD Ryzen 9000 processors!
Vengeance a7400: pre-assembled Corsair PCs with Ryzen 9000!
Corsair Vengeance a7400In terms of configuration, this range of PCs features the latest AMD Ryzen 9000 processors… At least, those currently available (tested here). So you can choose between machines equipped with Ryzen 5 9600X or Ryzen 7 9700X.
On the graphics card front, Corsair has chosen NVIDIA models with RTX 4060, RTX 4060 Ti, RTX 4070 Super and RTX 4070 Ti Super.
Finally, the storage section features a 1 TB PCIe SSD, while the memory section is equipped with 32 GB DDR5 running at 6000 MT/s.
As for the cooling system, the machines are equipped with 120 mm or 240 mm all-in-one watercooling kits, depending on the CPU installed. In all cases, we’re treated to an 80 Gold-certified 750W power supply, coupled with a motherboard equipped with a B650 chipset .
All that remains is to talk about prices, which range from $1699.99 to $2499.99 depending on the version!
Here are the Corsair product sheets!
