V11 : a vertical or horizontal ITX case all rounded !
This morning, we go to Jonsbo which announces a new mini-ITX case. This new model, named V11, offers a rather original design with the possibility to mount it vertically or horizontally.
V11: a new mini-ITX case by Jonsbo!
Jonsbo V11In the program, the brand offers us a new compact case. Indeed, this V11 has dimensions of 170 (W) x 353 (D) x 217 (H) mm. As for the materials, it is simple, steel for the interior, aluminum for the exterior. Moreover, the exterior design remains sober, Jonsbo obliges, nevertheless, the brand relies on a design all in roundness.
Inside, as we said, we have room for a mini-ITX motherboard. For the CPU fans, you don’t have to be greedy either, with a maximum height of 70 mm. As for the power supply, this model will only be able to accommodate an SFX block, but considering the format, this is not shocking. Finally, for the GPU, the card will be able to measure up to 330 mm without the front fan. With it, we go down to 300 mm, that said, we have three slots thick.
For the storage part, the brand puts forward two 2.5″ slots. Obviously 3.5″ units are not tolerated.
Finally, as far as cooling is concerned, things are also getting more complicated. Indeed, this reference will only be able to accommodate a single 140mm fan in the front. The same goes for the watercooling radiators: 140 mm all the same. In this format, we have seen better.
We finish by mentioning the possibility of installing it horizontally or vertically. For this, we have a system of feet in the accessory part. Similarly, in order to let the graphics card and the processor breathe, we have the right to mesh openings at their level.
Here is the technical data sheet of Jonsbo!
