V SFX Gold White Edition: Cooler Master SFX blocks in white!
Cooler Master announces new power supplies with its V SFX Gold White Edition. You will have understood, we are dealing with ultra-compact power supplies in white color. Concerning the power, two models are proposed: 750W and 850W!
V SFX Gold White Edition: the same, but in white!
Cooler Master V SFX Gold White Edition With this new series, the brand announces the arrival of two new power supplies. The powers go up to 750W for the smallest and 850W for the biggest model. Moreover, we find a certification in 80+ Gold ensuring a good performance.
Concerning the format, you will have understood it, we have to deal with ultra compact blocks since in SFX. The result is dimensions of 125 (W) x 100 (D) x 63.5 (H) mm.
Internally, the brand opts for a 92 mm active fan, but announced as silent. Similarly, we will find a single 12V rail of 62.5A (750W) and 70.8A (850W) as well as the following electrical protections: OVP, OPP, SCP, OCP, UVP, OTP, etc.
Finally, as far as the connectors are concerned, we can find the necessary power for ITX configurations with :
  • 1x ATX 24 pins (30cm) via one cable
  • 2x EPS12V 8-pin and 4+4-pin (45cm) via two cables
  • 4x PCIe 6+2 pins (40cm + 12cm) via two cables
  • 8x SATA (10 cm + 11.5 cm + 11.5 cm + 11.5 cm) via two cables
  • 4x Molex (10 cm + 11.5 cm + 11.5 cm + 11.5 cm) via one cable
For the moment, no price, but we know that the warranty will be 10 years!
Go here and there for the technical data sheets of Cooler Master !
