Tryx’s Luca L70 box arrives in Europe!
The TRYX brand is coming to Europe, as we’ve seen with their AIO Panorama, but Luca is also on the market here. You might ask, “Who the hell is Luca? Well, it’s simply their case, the Luca L70, a modular E-ATX reference!
Luca L70: the Tryx box arrives in France!
Tryx Luca L70
With this model, the brand is doing things right by offering a reference with a certain modularity. For example, the power supply can be moved from the bottom to the top of the case. Likewise, the motherboard tray ( E-ATX compatible) is removable, allowing independent mounting of the motherboard and a watercooling system, for example. The graphics card (460 mm long) can also be mounted vertically, if required.
Inside, there’s plenty of space for watercooling systems. In fact, this model can accommodate radiators up to 420 mm in length on the top and side of the motherboard. If the power supply is mounted at the top, there’s space at the bottom for a 360 mm radiator, as well as 240 mm at the top and 420 mm at the side!
The storage section offers significant capacities, with two 3.5″ slots, but above all nine 2.5″ SSD slots.
Finally, the case remains imposing, measuring 262 (W) x 540 (D) x 572 (H) mm, all for a weight of 16.2 kg. Quite a baby, that Luca.
Here’s the Tryx product sheet!
