Toughpower SFX: new power supplies join the series!
Thermaltake, completes its Toughpower SFX power supply series with the arrival of three new blocks. As a reminder, the initial series included 450W, 550W and 650W models. Now the range goes up to 1000W in SFX-L format!
Toughpower SFX : up to 1000W of power!
Thermaltake Toughpower SFX GoldThe SFX power supply also means reduced dimensions with depths of only 10 cm for the 750W and 850W models. Moreover, the 1000W version is a bit bigger: SFX-L, the depth is 126 mm.
As we said, the series benefits from the addition of three new powers 750W, 850W and 1000W, all certified 80+ Gold! In order to save space, the cable management is fully modular and they are flat and black. No sheathing here, which is a shame.
Internally, these models have a single 12V rail whose intensity varies according to the output power. The brand also mentions a strict regulation of voltages, a ripple noise lower than 30 mV and a current maintained during 17 ms in case of power failure.
Of course, ventilation is provided by 92 mm (750W – 850W) and 120 mm (1000W) fans. The operation is semi-passive up to 30% load and silent even at full power.
Finally, we find blocks that comply with the ATX 3.0 and PCIe 5.0 standards. These are well equipped with the 12VHPWR connector in 12+4 pins.
Regarding the prices, they are 244.90 € for the 1000W model, 194.90 € for the 850W version and 169.90 € for the 750W.
This way to the Thermaltake datasheet !
