ToughLiquid 240 aRGB: new colors for Thermaltake AIOs
Color on Thermaltake products has been coming for a while now. It started with fans, then with cases and until now, with fans. This time, it’s the turn of the AIO ToughLiquid 240 aRGB to go green and turquoise with these new versions!
ToughLiquid 240 aRGB: green and turquoise AIOs from Thermaltake!
Thermaltake TougLiquid 240 aRGB Racing Green As a reminder, with these kits, the brand offers us 240mm AIOs equipped with two ToughFan 12 fans. For the rest, we find a pump with aRGB lighting and a logo that can be oriented as we wish. Similarly, on this same pump, we find the RGB controller that will be controlled via three integrated buttons.
Nevertheless, the particularity of these models is to be displayed in Racing Green or Turquoise. This color is found on the cable sheath, the pump, the fans, but also on the radiator. Thus, you can completely match your setup with a rather original color.
Thermaltake TougLiquid 240 aRGB Turquoise
Finally, as a reminder, the fans benefit from a PWM type power supply and operate from 500 RPM to 2000 RPM. At full speed, the airflow will be 58.35 CFM and the static pressure will reach 2.41 mmH2O. In fact, these mills are quite efficient and compete with the NF-A12x25 from Noctua. We tested them here. For the moment, no price, but the data sheet is online, you can find it on the link below:
This way to the Thermaltake datasheet!
