Small novelty from Sharkoon which announces a medium tower case TK4 RGB. A new model rather classic in itself, but which integrates four aRGB fans as standard. At least, as a user, you don’t need to buy an extra pack of fans to have a good airflow… At least in theory.
TK4 RGB: one case, four fans as standard!
With its new case, the brand offers a medium tower model with dimensions of 190 (W) x 400 (D) x 456 (H) mm. The weight remains very contained with only 5,3 kg.
Inside, we find the classic motherboard support in ATX, micro-ATX and mini-ITX. Also, seven expansion slots are included for your daughterboards. Speaking of which, you should know that the latter can measure up to 335 mm in length. While we’re on the subject, the CPU fans are 157 mm high and the power supply 175 mm deep.
The basic cooling comes with four 120mm aRGB fans. Three of them take place at the front while the last one is installed at the back. Nevertheless, you will have two 120/140 mm slots available at the top. For watercooling, this TK4 RGB theoretically accepts 240 mm and 360 mm. We say theoretically because the brand does not stipulate radiator compatibility on its data sheet. Be careful on this aspect.
Finally, for storage, we have the right to five storage slots mixing 3.5″ (2x max) and 2.5″ (5x max).
For the moment, we do not know the price yet. On the other hand, it should not be exorbitant since there are expansion slots to be torn out. This remains symptomatic of affordable cases.
Here is the technical sheet of Sharkoon !
