TK-3: a medium-tower case with curved glass from Jonsbo
After unveiling its TK-1 and TK-2 cases, the Jonsbo brand follows up with the TK-3. We now have a whole range of cases for all motherboard formats, from ITX toATX!
TK-3: a case with curved side glass for ATX motherboards!
Jonsbo TK-3With this new case, we return to the gimmick of the other models in the series: the curved side glass panel extending all the way to the front panel. This provides a clear view of the configuration, while eliminating the need for a pillar to obstruct the view.
At 288 (W) x 438 (D) x 415 (H) mm, this model is larger than previous versions. As for weight, please allow for 7.3 kg on the scales.
Inside, there’s plenty of room for an ATX-format motherboard. Likewise, there’s plenty of room for the graphics card: 420 mm, and an ASUS Strix will fit without a hitch, according to the visuals. Finally, the CPU cooling unit is 165 mm high.
Jonsbo TK-3
With ten 120 mm fan slots, ventilation can be quite substantial. As for watercooling, compatibility with radiators stops at 360 mm… Sufficient for most cases.
Finally, let’s not forget to mention the compartmentalized design of this model. Power supply and storage are located at the rear of the motherboard tray.
As for prices, they can be found on Aliexpress at around a hundred euros at present. However, the crossed-out price is around €190.
Here’s the Jonsbo product sheet!
