TK-0 and T6, Jonsbo cases with wood!
Once again, we dive into the world of PC cases, but with references from Jonsbo and mini formats. The brand is announcing its TK-0 and T6 compact models. To make its mark on the market and offer distinctive features, the brand is opting for wooden parts!
TK-0: wood and curved glass!
Jonsbo TK-0
With this case, the brand offers us a highly original reference with its cube format. This model features a curved glass panel and a compartmentalised design. Despite this, the brand is keen to offer compact dimensions of 235 (W) x 250 (D) x 280 (H) mm. This is also a reversible model that can be positioned vertically or horizontally.
Internally, there is, of course, an ITX support for motherboards, while graphics cards are limited to 23 cm in length. As for the CPU cooler, we’ll be able to fit small 92 mm models, since the height is 135 mm, while the SFX-format power supply should be no more than 160 mm deep.
Finally, there are four ventilation slots: 1×120/140 mm at the top and bottom and two small 90 mm slots at the rear.
Price: €129.90!
The T6: a carrying handle!
Jonsbo T6The T6 is the second case to feature wooden components. As you can see, both the control panel and the carrying handle are made from this material.
Otherwise, we’re still dealing with a compact reference measuring 185 (W) x 223 (D) x 332 (H) mm. In terms of motherboard compatibility, we’re naturally limited to the mini-ITX format. However, it offers more space for the CPU cooling unit, which is reduced to 159 mm on AMD CPUs compared to 160 mm on Intel CPUs, the difference in thickness of the IHS being taken into account here. As for the graphics card, we’re back down to a maximum of 215 mm, but we gain an ATX format power supply support (14 cm max).
Finally, in terms of ventilation, we have a 120/140 mm slot at the front and a 120 mm slot at the rear.
Prices start at €149.90.
Jonsbo’s product sheets can be found here and here!
