Thermaltake Launches Pacific TF3 Monitoring System in 120mm
Thermaltake announces a clever little accessory for your PC and your custom watercooling loop. The brand presents its Pacific TF3 Liquid Cooling Dashboard, a monitoring system for your installation. The little trick lies in its 120 mm format that can be mounted quite easily!
Pacific TF3 : a 120 mm monitoring screen !
Thermaltake Pacific TF3 Liquid Cooling DashboardIn the program, we find a monitoring system for custom watercooling mouth. This last one arrives in a well known format since it is a 120 x 25 mm dial, the format of a classic fan. You will have understood, the interest of the thing is to be able to mount it on a fan slot in your case… Or, why not, on a watercooling radiator.
In any case, this dial will allow you to monitor several aspects of your installation. Indeed, it will be possible to keep an eye on the temperature of the liquid, the pressure inside the loop and the ambient temperature in the case. For this, different probes are provided, some of which can be integrated directly into your loop via G1/4″ ports.
Finally, a small aspect of customization is possible via a management of the color of the various dials. For this, we will go through the software of the brand via a USB control.
As for the price, it will cost $119.99 via the brand’s store.
This way to the Thermaltake technical sheet !
