Thermaltake introduces its AIO TH V2 Ultra Ex ARGB
Thermaltake has announced new all-in-one watercooling kits. These include the TH V2 Ultra Ex aRGB Sync Snow. This series comes in a range of sizes, features an LCD screen on the pump and a new fan!
TH V2 Ultra Ex aRGB Sync Snow: all-white kits with screen!
Thermaltake TH V2 Ultra Ex ARGB Snow Sync
The programme includes a series of watercooling kits in a range of sizes. In fact, the largest of them comes with 240/280/360/420 mm radiators. Of course, with a 420 mm radiator, be careful with the size and make sure your case is ready for it.
Otherwise, there’s a 2.1″ LCD screen on top of the pump. This will be used to monitor certain elements of the configuration, such as CPU temperatures, for example.
Ventilation is provided by CT120 EX or CT140 EX fans, depending on version and radiator size. These will enable management via a single cable, as they connect to each other via their frames. This simplifies cable management in your box. What’s more, to ensure a better connection, the contacts are wider than before.
In terms of features, we have :
  • 120 mm:
    • Speed: 500 to 2000 rpm
    • Air flow: 68 CFM
    • Static pressure: 2.95 mmH2O
  • 140 mm :
    • Air flow: 90.3 CFM
    • Static pressure: 3.07 mmH2O
Finally, the pump runs from 1500 to 3300 rpm. As for socket compatibility, this is guaranteed for all current platforms, even older ones such as LGA-1156 or AMD FM1.
Here are the Thermaltake product sheets!
