Thermaltake announces the View 270 TG aRGB!
In the world of PC cases, it’s all about fashion. At first, cases were ugly, then they looked like spaceships, then they had plastic windows, then glass, then mesh became ubiquitous… And now, aquarium-style housings are in vogue. Thermaltake is no exception, with its View 270 TG aRGB!
View 270 TG aRGB: an aquarium-style case with no visible front pillar!
Thermaltake View 270 TG aRGBAs you can see, this new case is available in a wide range of colors. The program includes white, black, matcha green and blue. This model follows the current trend for aquarium-style cases with a glass front panel and no central pillar, offering a clear view of the configuration.
Dimensions: 230 (W) x 456 (D) x 454 (H) mm, weighing in at 6.3 kg.
Internally, the motherboard tray will accommodate a model in E-ATX/ATX/µATX/mini-ITX format. For the graphics card, we find 420 mm in length, 180 mm in height for the CPU cooler and 220 mm in depth for the power supply.
This case can accommodate 360 mm high watercooling radiators, as opposed to 120 mm at the rear. At the same time, its compact dimensions make it impossible to mount larger units. As for ventilation, we can fit a total of nine 120 mm fans.
No price yet.
Here’s the Thermaltake product sheet!
