The Tower 600, another octagonal case from Thermaltake
On the Thermaltake side, we note the arrival of a new case reference with the The Tower 600. This new model follows in the footsteps of The Tower 300, designed to accommodate micro-ATX motherboards.
The Tower 600: the version for ATX motherboards!
As with the Tower 300, this is a reference with an original hexagonal shape. It also has three tempered glass panels to give a clear view of the entire configuration. What’s more, it can be mounted horizontally using a special bracket.
Internally, there is now support for motherboards in ATX format. What’s more, this compatibility is with so-called ‘ backpannel ‘ models or inverted connectors.
The cooling capacities are really advanced with a 420/360 mm AIO radiator support on the right coupled with a second 360 mm support on the left. As for cooling, there are thirteen 120mm fan slots and nine 140mm slots.
Finally, a few specifications:
  • Dimensions: 420 (W) x 286.4 (D) x 550 (H) mm
  • Weight: 9.7 kg
  • Compatibility :
    • Graphics card: up to 400 mm without power supply cover, 280 mm with one
    • CPU fan: 210 mm high
    • Power supply: ATX 220 mm deep
For the moment, this model is available in black, white, Hydrangea Blue and Matcha Green. No price yet.
Here are the Thermaltake product sheets!
