The Tower 200, an ITX case from TT compatible with RTX 4090
Thermaltake completes its series of cases The Tower with the launch of The Tower 200, a new model in mini-ITX format. However, it has a lot of space for the graphics card. It is said that it can accommodate an RTX 4090 without sweating!
The Tower 200: an ITX case that can accommodate an RTX 4090!
Thermaltake The Tower 200With this new model, Thermaltake offers us a case taking up the spirit of the other models of the series. Thus, we have the right to a vertical model with front glass. Moreover, the dimensions are rather imposing considering the format: 300 (W) x 280 (D) x 537 (H) mm. But it is a case that relies on its originality.
Internally, we find a motherboard slot in mini-ITX format. The graphics card support can be substantial: up to 380 mm by removing part of the power supply cover. Thanks to the three expansion slots, it is possible to mount an RTX 4090, provided that it is not too thick. Otherwise, the CPU fan and the power supply have 200 mm and 220 mm of height and depth respectively.
In addition, the cooling can be consistent since up to six fans in 120/140 mm can be integrated. As for watercooling, the support of 240/280 mm radiators is provided via a side plate.
For the moment, no selling price announced, we will have to wait a little longer.
Here is the technical sheet of Thermaltake !
